Ðề: SPACE CLAIM ENGINEER thiết kế 3D
Cho em hỏi phần mền này dung lượng bao nhiêu vậy ? cấu hình pc như thế nào thì có thể xài được? và có phần help hay tài liệu ko ? Thanks
Phần mền này khá nhẹ dung lượng bộ cài khoảng 660MB hoặc hơn một chút tùy phiên bản. Cài ra ổ cứng khoảng tầm 500Mb khá nhẹ.
Cấu hình cài bản 2009 có thể xem trên trang chủ như thế này:
System Requirements
System requirements for all SpaceClaim products.
Operating Systems:
Microsoft® Windows XP with Service Pack 2 or later
Microsoft® Windows Vista™ or later
SpaceClaim is not supported running on emulated or a virtual Windows environment (see note below). However, Intel-based Apple hardware running native Windows using Boot Camp is subject to the same hardware requirements as other Intel-based hardware.
Video Card:
Requires Full DirectX® 9c, February 2007 edition or greater, hardware support, 64 MB of graphics memory or higher, Shader 2.0 hardware support, 32 bits per pixel, 1024x768 minimum resolution. Please ensure that you have the latest graphics driver for your card and that Direct3D Acceleration is enabled (use the 'dxdiag' tool to check this).
The following commonly used video cards support the above requirements (1):
Radeon®:
ATI® Radeon R300, R420, R520, R600, or R700 series.
Radeon 9x00 cards (9700, 9800, …) or newer
NVIDIA®:
NVIDIA GeForce® FX, 6, 7, or 8 series. NVIDIA FX5200s or newer
AMD™:
AMD FireGL™ T2-128 or higher (including the ‘Mobility’ series for laptops)
Video Requirements Diagnostic Tool
This downloadable tool will automatically check that your video hardware and configuration meets SpaceClaim requirements
CPU:
Pentium® 4 2.0 GHZ or Athlon® 2000+ or faster, 32-bit (x86) or 64-bit (x64) processor
RAM:
Minimum: 512MB RAM (32-bit), 1Gb RAM (64-bit)
Recommended: 2GB RAM or higher, 256MB of graphics memory
Other:
2GB of available disk space(2)
DVD drive(3)
Microsoft Internet Explorer® 5.5 or higher(4)
CD drive (only for CD installation)
2 Button Mouse with Wheel
USB Spaceball (Optional)
More infomation
Click here
