Abaqus
P
phamphong13111998
Em chào ac và các bạn! E mới tìm hiểu về Abaqus. Em muốn thay đổi tỷ lệ mô hình trong Abaqus. Liệu trong abaqus có tính năng Scale không? Mong mn chỉ dùm e với !
U
umy
http://130.149.89.49:2080/v6.10/books/usi/default.htm?startat=pt05ch53s04hlb02.html
53.4.2 Scaling coordinates and shrinking the model
You can magnify, reduce, or otherwise distort the shape of your model by scaling, and you can shrink each element about its centroid. Scaling modifies all nodal coordinates in each of the X-, Y-, and Z-directions. Shrinking reduces each element in size uniformly about its centroid. For example, the elements shown in Figure 53–6 have been shrunk by a factor of 0.40.
Figure 53–6 Elements showing the effect of shrinking.
Scaling and shrinking options are plot state–independent; that is, you set them once for all undeformed, deformed, contour, symbol, and material orientation plots. You can also set the scaling and shrinking options that Abaqus/CAE will apply to the undeformed shape when the deformed shape is superimposed on it.
To scale or shrink your model:
  1. Locate the common or superimposed Scaling options. The common scaling options always apply to the deformed shape; they apply to the undeformed shape when it is plotted individually in any plot state (undeformed, deformed, contour, symbol, or material orientation). When the undeformed shape is plotted with the deformed shape, the superimpose scaling options apply.
    From the main menu bar, select Options
    Common
    or Superimpose; then click the Other tab in the dialog box that appears. Click the Scaling tab; the Scaling options appear.
  2. Toggle Shrink elements to request or suppress shrinking each element about its centroid.
    1. When Shrink elements is on, the shrink Factor slider becomes available.
    2. Drag the Factor slider to the desired shrink factor.
      A value of 0.00 indicates no shrinking. A value of 0.90 shrinks all elements to dots.
  3. Toggle Scale coordinates to request or suppress model scaling by nodal coordinate X-, Y-, and Z-directions.
    1. When Scale coordinates is on, scale factors become available. Click the X, Y, and Z boxes to enter scale factors for the X, Y, andZ nodal coordinates, respectively.
  4. Click Apply to implement your changes.
    The model display changes according to your specification.
    Your changes are saved for the duration of the session and will affect all subsequent plots in the current viewport and in any new viewports created from the current viewport.
