Bác nào có phần mềm chuyển file html và pdf về word không ạ?
bác nào có thì cho em xin với
em down trên mấy trang nó dều không có seri thế là không dùng dc.
All Office Converter Platinum 6.2
All Office Converter Platinum is an easy-to-use and professional document conversion tool. It can support batch converting documents, web and images with high good quality for business and individual to improve the work efficiency. With this powerful converter, you can create PDF file from versatile formats and convert PDF file to other versatile formats with super output quality and effectively. More, you can convert between different office document formats, web, images. It can support comprehensive formats: Word(doc, docm, docx), Excel(xls .xlsx. xlsm),PowerPoint(ppt, pptc, pptm),PDF,XLS,RTF,TXT,HTM/HTML,Website,JPG,BMP,GIF,TIF,WMF,EMF,TGA, RLE,PNG etc.
Advance Features:
• Provide the customized Command Line service for server/developer.
• It can simultaneously convert different formats to one certain format once.
• It can convert the webpage on the website or your computer.
• Easy to use. Convert with one click.
• More setting options to let you control the output file more accurately.
• Save the imported file list.
• Support encrypted PDF.
• Create PDF and Image with high good quality.
• Open *.HTM or URL as the following framework to convert
Support Formats
- Batch Convert Word(doc,docm,docx), Excel(xls.xlsx.xlsm), PowerPoint(ppt,pptc,pptm),RTF,TXT,HTM,HTML,Website ,JPG, BMP,GIF,TIF,WMF,EMF to PDF(as default format, as image format,as text format).
- Batch Convert PDF to DOC,RTF,XLS,HTM,TXT, JPG, BMP, GIF, TIF, TGA, RLE, PNG, EMF, WMF.
- Batch Convert Word(doc,docm,docx) to PDF (as default format, as image format, as text format),XLS,TXT,HTM,JPG,BMP,GIF,TIF,TGA,RLE,PNG ,EMF,WMF.
- Batch Convert PDF, Excel(xls.xlsx.xlsm),TXT,HTM,HTML,JPG, BMP, GIF, TIF, EMF, WMF to DOC.
- Batch Convert PowerPoint(ppt,pptc,pptm) to JPG, BMP,GIF,TIF,TGA,RLE,PNG,EMF,WMF,DOC,XLS,RTF,TXT,PD F(as default format,as image format, as text format).
- Batch Convert HTM,HTML,Website to DOC,PDF(as default format, as image format, as text format),TXT,RTF,XLS,JPG,BMP,GIF,TIF,TGA,RLE,PNG ,EMF,WMF.
System Requirements:
- 733 Mhz Pentium ll CPU or higher;
- 128 MB RAM Memory or higher;
- 20 MB free hard drive space
- Windows/98/ME/NT/2000/XP/2003 Server/Vista
- MS-office2000 version, or higher
- Adobereader 7 or above, or highter,if you control about pdf file
- IE 6.0 or above;
Serial
Code:
Serial : 75011162191391210808
Nguồn softvnn
