Ðề: AUTODESK MOLDFLOW 2010 Source
Anh Linh em làm theo cách của anh,và có tham khảo 1 số nơi khác mà vẫn không được giận quá giận :46: cách làm như sau,cái hình ở dưới là thông báo lỗi,anh còn cách nào nữa chỉ tụi em với
All installed and XP, and 7:
1. install any components MOLDFLOW (which you need), the license manager is installed by itself or asks for confirmation, confirm and install.
2. Next, from your MAGNiTUDE:
the XP copy all the files where you want, in your Autodesk Network License Manager creates a text file log.txt, then with notepad open the file and it License.dat instead this_host enter your computer name (hostname);
for 7 first from your MAGNiTUDE / Program Files / Autodesk / License Manager (Moldflow) copy the file in the folder adlmdll.dll with program's on the C drive, then create a folder MAGNiTUDE / Program Files / Autodesk Network License Manager text file log.txt, with further Notepad open the file and it License.dat instead this_host enter your computer name (hostname) and only copy the contents of this folder to Autodesk Network License Manager on the C drive (all done in administrator mode)
3. Configuring the License Manager FlexLM, for this run LMTOOLS (for 7 to run in administrator mode), in accordance with guidelines for installation:
In the window that appears, select the tab "Config Services", and specify the file path to
start the server.
A. "Path to the lmgrd . exe file "browse" C: \ Program Files \ Autodesk Network License Manager / lmgrd.exe "
B. "Path to the License file", specify the path "C: \ Program Files \ Autodesk Network License Manager / license.dat"
C . "Path to the debug log file", specify the path "C: \ Program Files \ Autodesk Network License Manager / log.txt"
in the options to tick the box "Use Services" and "Start Server at Power Up"
then click "Save Service".
Then select the tab "Start / Stop / Reread", and click "Start Server".
You can go to Lmtools tab and click the Server Diags Knop Perform Diagnostics - If all did the right thing should be all set (ie, your license should be tested and in the window of the report will say about it.)
4. Start MOLDFLOW.
if you do not work sledueschee:
read half a page
http://www.moldflow.com/download/prod_mps/english/t...bleshooting.html where they write about the changes to the registry and climb into the registry.
[HKEY_LOCAL_MACHINE \ SOFTWARE \ FLEXlm License Manager]
"Service" = "Flexlm Service 1"
"FLEXlm License Manager" = "@ hostname" <- this line should be added instead of the hostname of the computer to substitute the name
"ADSKFLEX_LICENSE_FILE" = "@ 127.0.0.1"
Section [HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ Autodesk License Manager (Moldflow) Daemon] create a
Value DependOnService and substitute the value of the service name of the license manager. I like Flexlm Service 1, at the end press Enter and OK. In general, see the above link, the page with the pictures there.
And yet, go to Start - Autodesk - License Manager (Moldflow) and run the Network License Server Settings, there should be 127.0.0.1.
Reboot and try to run the Moldflow
Đây là cái hình mà em cài đi cài lại vẫn bị
,dù đã cài lại WIN tức thì thôi rồi mà :102:,anh còn cách nào hướng dẫn với anh .
