Cnckad phần mềm dành cho những ai chuyên ngành dập tấm
thehk3
PHIÊN BẢN MỚI NHẤT HIỆN NÀY
cncKad 9.5.177 + update build 198(Eng/Rus)
Metalix presents the complete CAD/CAM solution for Sheet Metal manufacturing.The Complete CAD/CAM Solution
cncKad is the only software which has integrated CAD/CAM capabilities in the same module: Geometry, Dimensions and Technology (Punching/Cutting) are completely associative - when the Geometry is modified, Dimensions and Technology are automatically updated!
cncKad features 2D & 3D design, Automatic Nesting, NC Generation, Graphic Simulation and Machine Comunication.
Import and Export - 3D integration with Solid Works, SolidEdge, Autodesk Inventor and ProE, through the associative link, and read files directly from AutoCAD.
cncKad fully compatible with Windows Vista and Office 2007
Plotting – effective and at the same time simple in use two-dimensional (2D) the drawing module supporting in addition to a totality of usual drawing tools special auxiliary means for work with sheet metal, including: creation of dredging, facets, interfaces; automatic detection and correction of not closed contours, recognition of forms, check of drawings and use
of fonts.
Processing – automatic and interactive graphic processing for technologies of punching, and also laser and plasma are sharp, autogenous and water abrasive processing, including: automatic репозицию, avoiding of clips, processing on strips, sheet cutting off, support of tools of family Wilson Wheel, minimisation of rotation of the tool and creation of the entire accounts. This module supports also automatic punching and резку, use of special tools, репозиции, joint раскрои and so on.
AutoNest – an automatic apportion of details of difficult forms for optimum use of a material, by means of such functions
tools as interactivity, grouping, a grill, filling of apertures, creation repeating нестингов, automatic transfer DXF, creation of the entire accounts.
The post-processor – post-processors generate the effective codes including subroutines (Macroes), optimisation of a trajectory of moving of the tool, minimisation of rotation of a revolver of the machine tool, and also support of such functions of the machine tool as greasing, vacuum and the control of speed of punching (ram-rate).
Simulation – Graphic simulation of work allows to edit with ease codes УП during viewing of results of processing.It is automatically checked on presence of errors, such as: absent parametres, problems with clips, an exit for table limits and so on.
The option allows to transform ready codes again to drawings and to feign their processing.
DNC – module DNC supports sending of files in the controller of the machine tool and their reception, and also supports data transmission and extraction of ready codes УП from the machine tool controller.
OS: Windows NT/2000/XP/Vista
PHẦN MỀM NÀY RẤT HAY.VỚI SỰ KẾT HỢP VỚI AUTOCAD VÀ CÁC PHẦN MỀM ĐỒ HỌA 3D(SOLIDWORKS, INVENTER) MANG LẠI TÍNH HIỆU QUẢ CHO NGƯỜI SỬ DỤNG.
CÔNG TY MÌNH ĐANG SỬ DỤNG PHẦN MỀM NÀY.
CÁC BẠN TẢI VỀ DÙNG THỬ NHA.
NẾU BẠN NÀO BIẾT CÁCH CÀI ĐẶT THÌ ÚP HƯỚNG DẪN CÀI ĐẶT NÊN, CÒN MÌNH CHỈ BIẾT DÙNG THÔI, CHƯA BIẾT CÁCH CÀI ĐẶT.HJHJHIJ.
http://letitbit.net/download/974 ... .5_r.part1.rar.html
http://letitbit.net/download/260 ... .5_r.part2.rar.html
http://letitbit.net/download/991 ... .5_r.part3.rar.html
http://letitbit.net/download/873 ... .5_r.part4.rar.html
http://letitbit.net/download/835 ... .5_r.part5.rar.html
http://letitbit.net/download/982 ... .5_r.part6.rar.html
update:
http://www.4shared.com/file/130906376/eb11300f/update_95177.html
http://www.4shared.com/file/130906385/f5807d7a/update_95198.html
rarpasw: mambablack
LINKS KHÁC
cncKad 9.5.177 + update build 198 (Eng/Rus)
http://rapidshare.com/files/257514636/cncKad_9.5.177_www.softarchive.net.part1.rar
http://rapidshare.com/files/257520138/cncKad_9.5.177_www.softarchive.net.part2.rar
http://rapidshare.com/files/257524374/cncKad_9.5.177_www.softarchive.net.part3.rar
LINKS KHÁC
http://rapidshare.com/files/2575 ... chive.net.part1.rar
http://rapidshare.com/files/2575 ... chive.net.part2.rar
http://rapidshare.com/files/2575 ... chive.net.part3.rar
Ðề: Cnckad phần mềm dành cho những ai chuyên ngành dập tấm
Bộ cài thì ok nhưng ***** thì không ổn lắm. So với bản 8.0 thì bản này có nhiều tính năng hơn thật. Soft này có mấy ông bên Trung Quốc chuyên ***** nhưng hiện tại thì chưa có ***** chuẩn, phải đợi thôi.
#3
anh thehk3 à em không biết cách tải về phần mềm này vì em không biết tiếng nga. Anh có thể gửi vào mail( hoangancks@gmail.com ) cho em được không em cảm ơn nhiều lắm!
#4
Bạn nào có thể up lại phần DNC trong bộ cài 9.0 hoặc 9.5 được không, mình đang rất cần. Về phần cài cnckad nếu ai cần mình có thể up lại với đầy đủ crack. Liên hệ inbox hoặc mail cá nhân.
Cảm ơn !
#5
Cảm ơn !
bạn cho mình phần mềm và crack với minh cam ơn nhiều: ngocdieu020484@gmail.com:76:
#7
Phần mềm mình có file up trên box.com, bạn nào cần thì gửi vào hòm thư meslab, mình ko muốn dùng mail riêng. Cũng mong các bạn đừng chia sẻ link trên các diễn đàn, vì file có thể sẽ bị người quản trị xóa vì vi phạm bản quyền.
#9
bạn nào biết cách crack giúp mình với, mình cài xong, coppy file .reg vào thư mục cài đặt, chạy nó..
xong rồi chyaj chương trình cnckad nhưng nó báo lỗi:
[/URL][/IMG]
Mình cài thêm cái NetHASP, sau đó chạy lại cnckad thì lại có lỗi:
[/URL][/IMG]
bạn nào biết cách crack giúp mình với.
mail mình là xanh89xanh@gmail.com.
Thanks!
#10
Mình cài được rồi, lúc trước không xem kỹ file crack nên không crack được :D :D
cám ơn mọi người nhiều.
#11
bạn có thể cho minh phần mềm + crack không?mail:luongnx02@gmail.com
Thank!
#13
có anh chị nào biết về dynaform cho e hỏi e muốn nhập các thông số D=80,s=2,H=100,vật liệu SU304 thì e nhập thông số thế nào ạ?e chỉ biết làm theo video hướng dẫn cho nó chạy đc chứ ko biết nhập thông số của mình vào thế nào :( mong các a chị giúp đỡ ! e xin cảm ơn :)
vncdbt
bạn có thể cho mình bản full crack cnckad được không, tnchau82@yahoo.com.vn mình đang có máy mà ko biết dùng,Thanks bạn
#15
Bạn caominh0604
hỏi thế này chưa rõ nên cũng khó trả lời. Ý bạn ở đây là thông số sản phẩm của bạn có D=80, s=2, H= 100 hay là bạn hỏi về Đường kính phôi khi nhập vào phần mềm, hành trình vuốt hay thế nào. Có gì inbox câu hỏi cụ thể qua mail mình trợ giúp cho nhé: buidieubk@gmail.com
#17
mình có phần mềm nhưng không biết cách cài, nếu ai có thể hướng dẫn mình cách cài thì mình chân thành cảm ơn
#18
Em tải về cài nó báo lỗi này ai giúp em với.
[/IMG]
#19
m.n ai có phần mềm cnc 9.0 + crack thi cho em xin với ạ.thank m.n
#20
Cái này chuyên ngành thép tấm giúp được gì nhỉ. Ai có hình ảnh minh họa cho mình biết với.
