Mấy chiếc này thường dùng chuyên chở trong công nghiệp khai khoáng. Thông số tham khảo từ internet:
Operating Specifications
Nominal Payload Capacity - 380 tons / 345 tonnes
Nominal Payload Capacity - 339.55 tons / 345 tonnes
Top Speed – Loaded - 42 mph / 67.6 kph
Maximum Capacity - Custom
Steer Angle - 39 Degrees / 39 Degrees
Turning Radius – Front - 130.9 ft / 39.9 m
Turning Circle Clearance Diameter - 132.8 ft / 40.5 m
The Titan was powered by a 10,343
cid, 16-
cylinder 3300/3000
hp locomotive engine coupled to a EMD AR10-D14
generator. This Electro-Motive Division engine, as the 16-645E4
prime mover, was
aftercooled and
turbocharged. The generator then powered 4 electric
traction motors located at each rear wheel. The Terex featured large 40.00x57
tires made of rubber. It is 66
feet (20
m) long and 22.6 feet (6.9 m) tall; or 56 feet (17.1 m) tall with the dump body raised.
The T 282B has an empty
weight of 203
tonnes, and a maximum
capacity of 365 tonnes. The maximum operating weight is 592 tonnes.
[1] It is 14.5 meters long and 7.4 meters tall over the canopy, with a wheelbase of 6.6 meters. The top level model is driven by a 10.5 tonne, 90 litre
diesel engine, developed by
Detroit Diesel and
MTU (Germany), producing 3650
horsepower (2700
kW). This engine powers two
Siemens electric traction motors in the rear axle, so the truck is a diesel-electric
hybrid vehicle. The top
speed of the truck is 40 mph (65
km/h).
