Xin hỏi Giúp đỡ về tính ứng suất và độ võng trong inventor
Discussion in 'AutoCAD & Inventor' started by dhbachkhoa, Nov 14, 2016.
  1. cambodiaa
    cambodiaa New Member
    Ðề: Giúp đỡ về tính ứng suất và độ võng trong inventor
    Theo mình thì vấn đề là điều kiện biên
    Mình test thử trên ANSYS
    - Hai đầu X=Y=Z=0
    -Hai đầu X=Z=0, Y=Free
    Ps/ mình không biết chèn ảnh vào 4r thế nào :(
  2. Mrwind
    Mrwind Member
    mình cũng đang gặp vấn đề tương tự, mình ko thể rang buộc "gối đỡ" trong module Stress Analysis, mà chỉ có thể rang buộc gối trong Frame analysis. Các pro có ai biết định nghĩa "gối đỡ" trong stress analysis ko a?
  3. umy
    umy Well-Known Member
    Autodesk Knowledge Network
    https://knowledge.autodesk.com/
    Boundary patch features
    Feb 13 2014
    Applies to Inventor 2014
    Share
    Add to Collection
    The boundary patch feature generates a planar or 3D surface from a closed 2D sketch, a closed boundary, or a mixture of both. The patches default to contact (G0), but can have edge conditions of tangent (G1) or smooth (G2) applied to each model edge in the Condition list.
    Once the first closed loop is selected, you can begin selections for a second loop.
    You can also enable feature preview to view the results before creating the patch.
    Tangent continuous edges are chained together. Select Automatic Edge Chain to chain non tangent edges. You can undo the last selection in an edge chain, and repeat as needed. You can delete an item from the list.
    Methods to define boundary
    Region selection
    Select one or more closed 2D sketches to form the single region. When a closed sketch is selected, the corresponding region is highlighted in the graphic window and you are limited to creating a planar patch. This technique is the same as profile selection for Extrude.
    Sketch selection
    Select one or more closed 2D or 3D sketches to form a nonplanar patch. When a closed sketch is selected, the corresponding region is highlighted in the graphic window. Once the region is highlighted, you can use Select Other to select specific geometry within the sketch.
    Edge Selection
    Select edges which define a closed loop. Because continuous edges must have the same edge condition, all selected surface edges that are tangent or continuous with the previous item are merged. If you clear the Automatic Edge Chain check box, chaining stops at the first nontangent selection.
    Edge and Sketch selection
    A boundary can be defined by both edges and sketches. When you select a closed loop, the region is defined and highlighted in the graphics window. If preview is on, a preview also exists.
    For all selection methods, the OK command is enabled once a closed loop is defined so that you can select additional loops. By selecting additional loops, you can define inner and outer loops that make islands in the surface. If a planar region is selected, selection of additional loops is not allowed.
    Edge conditions
    Edge conditions can be applied to each nonsketch edge in the selection set for a loop. By default, all boundary segments are G0. You can apply G1 or G2 conditions to any non sketch edges only if they have a single adjacent face. Boundary edges can include a mixture of G0, G1, and G2 conditions. You can apply a weight factor for G1 and G2 edges.
    Tips for creating boundary patches
    • If you create a boundary patch with tangent constraints, avoid using supporting faces that are all perpendicular to one single imaginary plane. An angle that is not 90 degrees is expected.
    • Avoid creating a boundary patch on construction geometry that consists of a single segment closed curve (circle, ellipse, or closed spline).
    • For best results, stitch boundary patches to adjacent surfaces before creating features, such as sculpt, shell, and thicken/offset.
    Topics in this section
    Parent topic: Created features
    Related Reference
    ... more ...
  4. umy
  5. Mrwind
    Mrwind Member
    Cám ơn anh "umy" nhiều lắm. Em khai sang ra được vài vấn đề.
    Ah, anh ơi, trong module thiết kế khung "Frame Analysis" của Inventor mình có cách nào để add những tiết diện khung do mình thiết kế vào được không anh? chẳng hạn như tiết diện nhôm định hình.
    Em cám ơn nhiều.
  6. umy
    Chắc được mà ! tăng mặt cắt ngang (tiết diện khung) vào thư viện tư. Có xem trong Help chưa ?
    Tập tự tìm kiếm trong mạng và xem thêm hướng dẩn với tài liệu tiếng Anh đi chứ.
    KS dùng mềm ngoại mà chỉ hỏi và chỉ biết đọc tiếng Việt thì như Ếch ao làng, ngồi đáy giếng vậy !:35: !
    https://forums.autodesk.com/t5/inve...youtube]n-frame[/MEDIA]-analysis/td-p/2867528
    https://knowledge.autodesk.com/supp...[/MEDIA]-8CAC-46A4-BD67-E39D4BAC0997-htm.html
    Ðề tài: Những Câu Hỏi Về Inventor
    http://www.meslab.org/mes/threads/10241-Nhung-Cau-Hoi-Ve-Inventor.html
  7. Mrwind
    Mrwind Member
    để đọc được tiếng anh thì có lẽ anh Umy nên đọc tiếng việt trước chứ ạ anh nhỉ. Vì nhôm định hình thì đâu phải chỉ có tăng tiết diện theo 1 phương nào đó. =.='
  8. umy
    - Tôi công tác gần 50 năm ở ngoại quốc, nên không đọc tiếng việt trước ! chỉ dùng ngoại ngữ đọc vào thẳng !:25:! Tiếng Việt luyên tập lại khoãng 8 năm, (Rất tiếc! vẫn còn kém) Chủ ý chỉ để giúp đở các hậu bối trẻ tại VN thôi
    - Nhôm định hình có bảng theo TC Mỹ: AISC, Âu: EuroCodes ... hoặc Tài liệu nơi nào sản xuất, chịu khó gõ thêm vào thư viện tư để sử dụng. (Nên đầy đủ 6 thành phần để tính frames . Em Mrwind chưa có kinh nghiệm để tính Structural design and analysis nhỉ ?
    - Trong links tôi cho (ở Dđ ngoại) người ta có cho tài liệu và exel tiếng Anh để tính diện tích, mô men quán tính ...cho mặt cắt nhôm bất kỳ.... Cố gắn tìm hiểu chứ đừng tự ái, sù lông thì kém cỏi quá.!:50:!
    bonze likes this.
  9. Mrwind
    Mrwind Member
    Gửi chú "Umy",
    Trước tiên cháu thành that xin lỗi chú vì lời nói có phần thiếu suy nghỉ ở trên. Chú nói đúng cháu còn rất ít tuổi và chỉ mới gia nhập bộ môn tính toán kết cấu được 2 tuần tính tới bây giờ và chủ yếu là do tự tìm hiểu, cháu cũng siêng năng đọc tài lieu tìm cách tính toán sao cho hợp lý tuy nhiên do kinh nghiệm thiếu nên những lúc bị "dí" quá hay bị "rối". Xin lỗi chú và cám ơn chú đã chỉ ra một hướng cho cháu tìm.
    Tuy nhiên, có một vấn đề là khi tìm cách Frame analysis trong inventor không được thì cháu đã tự mò ra bang phần mềm SAP2000V14. Cũng tương tự cách mà cách mà trên link chú gửi, cũng nhập các thông số để tính ra moment quán tính, moment quán tính cục, boundary, E, poisson, Density, (các thông số đặc trưng tiết diện có thể dung autocad để tính)... nhưng cháu ko biết là có vấn đề gì với các góc bo, fillet, các góc uốn bí hiểm và tuyệt vời của các tiết diện profile định hình mà tính ra số nhỏ quá dù khi tính ngoại lực cháu đã đưa các hệ số an toàn vào. Hiện cháu cũng đang thử bài toán với cách biên đổi ma trận kết cấu, nhưng chưa có thời gian.
    Haizz, nói chung là cháu thiếu nhiều kinh nghiệm quá. Thành that xin lỗi chú, chau sẽ suy nghỉ kỷ hơn. hiccc
  10. umy
    Hằng năm các phần mềm đều đưa ra phiên bản mới, (chiến thuật cạnh tranh hiện nay để tranh thủ bán hàng), trong đó có Help giải thích ngắn gọn kịp thời.
    Sau đó gần cả năm mới có sách vở tiếng Anh do các GS.TS. ở ĐH viết thêm cho mềm mới. Qua đến 2, 3 năm họa may mới đươc vài Giãng Viên ở VN chép, viết, thông dich lại !:58:!
    Nhiều ct mềm của Âu châu rất hay, có từ khoãng 1980 đến 2000 ngã gụt chỉ vì tự ái dân tộc, sỉ hảo không dùng thẳng tiến Anh, Mà cố giử viết mềm và TL theo tiếng bản xứ (Đức, Pháp, Séc, Ba lan, Nga ...).Chỉ lòng vòng trong Ao nhà, không phát triển canh tranh nổi trên thế giới. Hiện nay họ đi thẳng vào tiếng Anh, dể phỏ biến các nới trên thế giới.
    Đã từng trãi qua nhiều; Vì thế nên tôi mới khuyên, nên đi thẳng vào TL tiếng Anh. Mới theo kịp người. Còn tự ái hay lười biếng chỉ chờ đọc xem tiếng Việt thì muôn đời đi sau thiên hạ; ... ít nhất là vài năm !:68:! Bạn trẻ đừng hờn nữa, Hiểu rồi chứ ?
    bonze and Nova like this.
  11. narita
    narita New Member
    em muốn tính độ võng của trục thì xem tài liệu nào vậy mọi người?
  12. umy
    Có phải em là cán bộ học tại chức đấy hả ?
  13. bonze
    bonze Active Member
    Chào chú Umy !
    cháu rất ngưỡng mộ sự nhiệt tình và kiến thức uyên thâm trong ngành kỹ thuật của Chú.
    Nhân tiện nói về đề tài tính ứng xuất này, Chú cho cháu hỏi hiện nay việc mô phỏng khuôn đột dập các chi tiết dạng tấm phẳng (dập vuốt các sản phẩm như nồi, xoong) thì hiện nay trên thế giới có phải họ dùng phần mềm Autoform ko ạ ?
    Hay họ dùng phần mềm khác sát thực tế hơn.
    Chú có nguồn tài liệu nào đơn giản, dễ thực hiện thì gửi cho cháu được ko ạ ?
    Cám ơn Chú !
    umy likes this.
  14. umy
    Để thích hợp cho vấn đề mô phỏng khuôn đột dập Autoform. Xin Anh bonze vào
    1) topic do thầy Dinh Ba Tru CAE và Metalformingvn lập ra, có thể thích hợp hơn
    https://meslab.org/threads/cae-va-metalformingvn-net.14000/#post-246339
    kỹ nghệ dập khuôn có nhiều phần mềm được lắm ! Vào đấy khi tìm được tài liệu nào, đưa lên trao đổi bổ ích chung cho tập thể .
    2) bên VUDSE, có rất nhiều cao thủ VN kiến thức giỏi, có kinh nghiệm rộng > trao đổi, học thêm biết được nhiều, ích lợi nhiều cho bản thân.
    https://www.facebook.com/groups/vudse/
    Mến chúc Anh Bonze đạt được kết quả.
    bonze likes this.
