Hỏi về lỗi cài đặt Solidworks
Giúp em với sau khi em cài SW xong khi chạy trương trình thì nó báo "SldWork has encountered a problem and needs to close.We are sorry for the inconvenience." và "If you were in the middle of something,the infommation you were working on might be lost." Ấn vào close thì nó out ra ngoài là sao vậy
cài thêm dot net frame 3.0, 3.5
Hey... I had the same problem until I read this on a tech support website:http://www.javelin-tech.com/main/support/solidworks_2009_faq.htm
‘SolidWorks Explorer has encountered an error’ is displayed while trying to start SolidWorks Explorer 2009.
This is a typical symptom of not having the .NET FrameWork 3.0 application installed on the PC running SolidWorks Explorer 2009. This is required for SolidWorks Explorer and SolidWorks 2009 to run. The .NET redistributable packages are included with the DVD or download. Browse the source of the installation (DVD, download folder, or Administrative Image). Go to the <source location>\<swwi>\data\DotNetFX and double click on dotnetfx3.exe for WinXP x32 and dotnetfx3_64.exe for WinXP x64. Once this is installed, run a repair of the SolidWorks Explorer Installation.
First, I had to download the .NET Uninstaller here:
http://www.microsoft.com/downloads/...63-D405-4E13-909F-E85AA9E66146&displaylang=en
Then I went to get the latest Windows .NET framework at windows website:
http://www.microsoft.com/downloads/...EDIA=youtube]1-413d[/MEDIA]-8319-81da479ab0d7
PROBLEMS SOLVED. I was happy and hope you can be too. Good luck!
Ðề: lỗi cài đặt solidwork
Bạn ơi bạn có thể giải thích bằng tiếng Việt về cách khắc phục lỗi này không? Mình cũng đang gặp vấn để về lỗi này của SW2009 sp0.Mình không down được 2 cái đó về. Cảm ơn mọi người.
mình cài 2 cái framework là hết lỗi à.
First, I had to download the .NET Uninstaller here:(cài bản này trước mà hình như mình cài bản này bị lỗi không cài được)
http://www.microsoft.com/downloads/d...displaylang=en
Then I went to get the latest Windows .NET framework at windows website:(sau đó cài bản này,bản này mình cài được và hết bị lỗi)
http://www.microsoft.com/downloads/d...9-81da479ab0d7
bạn nói không down được là sao có chữ download ngay phía dưới mà
Bạn ơi, làm phiền bạn up 2 cái đó lên mediafire hoặc gì đó giúp mình được không. Không hiểu sao minh không vào được 2 trang đó nữa. Cảm ơn bạn nhé !
Mình đã down về được rồi. File đầu lỗi thật, file 2 cài được nhưng vẫn không khắc phục được lỗi ấy.Không biết là phải cài 2 cái này trước khi cái SW không hay cái nào trước cũng được?Chắc là phải cái đủ cả 2 file mới khắc phục được. Có ai biết chỉ giúp mình với. Cảm ơn mọi người đã quan tâm !
Uhm. Cảm ơn bạn mình đã cài được SW2009 đúng là có hơi rắc rối trong việc cài đặt chút, tiện đây mình cũng chia sẽ luôn kinh nghiệm với các bạn. Các bạn có thể phải dùng đến framework, có thể down về từ các link trên, trong quá trình cài framework (cài online) nếu máy bạn bị virut thì bạn sẽ không thể cài được ( máy bị virut sẽ không thể vào khai thác các trang của microsoft). Vì thế sẽ phải cài lại win mới có thể cài đặt được framework và sẽ khắc phục được lỗi trên. Đây là cách của mình làm.
tchllvrm
Tôi download bản SW 2010 32bit về vài cài đặt, nhưng lại thấy báo lỗi winnt0.cab vì vậy không cài được.
Rất mong các bạn tìm cách khắc phục giúp tôi.
Mình nghĩ bộ cài bạn down về có vấn đề. Bạn có ở Hà Nội ko liên hệ mình cop cho.
Mobile 098 468 1986.
tchllvrm
cảm ơn Letai2906. Tiếc quá, mình ở Sgòn. Mỗi lần down thấy oải quá. Có lẽ phải làm lại một lần nữa xem sao.
TÌm trên mạng, thấy một số người cũng mắc lỗi winnt0.cab giống mình, nhưng ko thấy ai có cách giải đáp. Thật là chán.
Lỗi này có thể do win, bạn thử cài ở máy khác xem, hoặc cài lại win,
Mà bạn viết rõ thông báo của cái lỗi ấy là gì ra xem nào, chứ không hơi khó tìm các sửa, có phải lỗi này
Error 1335: The cabinet file WinNt0.cab required for this installation is corrupt and cannot be used
Win của bạn là XP SP3 phải không
hay win7
Nhiều khi win update lên bị lỗi như thế
tchllvrm
Hôm nay, mình đã down lại toàn bộ solidwork 2010 bản P0.0 cũng từ nguồn mediafire lần trước đã down xuống. http://www.mediafire.com/?sharekey=105f83ab2ca2908dab1eab3e9fa335cafc8fb6c99d146648
Gần 2 ngày miệt mài mới xong. Ghép file xong và cài đặt. Lỗi y chang như cũ. Mình không biết phải làm sao cả. Mong mọi người nghiên cứu lại giúp mình một lần nữa.
Rất có thể file winnt0.cab trong ..\swwi\data\ bị lỗi chăng. Vậy bạn nào có thể share cho mình riêng file này được ko.
sau đó là thông báo này. bấm OK, thoát khỏi cài đặt hỏng.
nick Y! của mình là letai2906. nháy mình gửi cho nha. mình đã cài thử solid 2006 trên vista thì nó báo rõ win ko phù hợp nên lỗi của bạn mình nghĩ do bộ cài thôi. thay vì down trên mạng, sao cậu ko đi ra cửa hàng làm cái đĩa về cài xem sao?
tchllvrm
biết là vậy rồi, nhưng chỉ sợ chạy ra hàng mua 2DVD về cài cũng bị lỗi tương tự trên máy mình. Khi đó không biết giải thích thế nào với người bán DVD. Máy bàn chứ không phải laptop, nên ko vác cái máy ra làm bằng chứng. Tiền mất mà lại ko có cái mình cần. MÌnh đang dùng Win7. Chả biết cài lại WIN có ổn ko.
Chả lẽ đành pó tay sao mọi người.
hay cậu thử mang sang cài ở máy dùng win xp xem sao? mình dùng vista nên ko rõ. nếu dc thì chứng tỏ tại win, đừng cài lại vội.
Virus
Các bác cho em hỏi là phiên bản 2k7 so với 2k8 và 2k9 sp.0 thì cái nào nhẹ nhất ạ? tại máy nhà em là Dual Core, 3.2 Ghz , Ram 1G , VGA 256. Mong các bác chỉ tận tình .Cảm ơn các bác
E có file *.iso. mount vào ổ ảo để cài thì có lỗi này. Sau e copy vào 1 folder thì cài bình thường. A thử lại xem sao. E cũng dùng win 7
P
phambinhcn
Mình cài SW 2010 nó báo phải khởi động lại máy. mình khởi động lại nó tự cài tiếp, sau đó nó cài dc khoảng hơn 10% thì dừng lại và treo máy. Mình khởi động lại nhưng ko vào dc win nữa. Mình ghost lại ổ và cài lại nhưng sảy ra lỗi tương tự. Không biết bị làm sao nữa. Bạn nào biết chỉ cho mình nhe.
