Chia sẻ Sử dụng ngôn ngữ lập trình trên nền phần mềm ANSYS công nghiệp để phân tích kết cấu
Discussion in 'CAE & CÁC PHẦN MỀM MÔ PHỎNG' started by Lethuy_hvkt, Nov 4, 2016.
  1. umy
    umy Well-Known Member
    ngôn ngữ lập trình trên nền phần mềm: ANSYS APDL ???
    Sai topic > Hawk Rigde Systems for SOLIDWORKS !!
    Persious likes this.
  2. Persious
    Persious Active Member Staff Member
    Cháu thấy cũng hay nên không để ý ạ, để cháu xóa bác Umy ạ! :p
  3. umy
    Bài tập 01 Ansys APDL cho SV tự học
    https://sites.ualberta.ca/~wmoussa/AnsysTutorial/AT/APDL/APDL.html
    This tutorial will cover the preprocessing stage of constructing a truss geometry. Variables including length, height and number of divisions of the truss will be requested and the APDL code will construct the geometry.
    Preprocessing: Use of APDL
    Shown below is the APDL code used to construct the truss shown above, using a length of 200 m, a height of 10 m and 20 divisions. The following discussion will attempt to explain the commands used in the code. It is assumed the user has been exposed to basic coding and can follow the logic.
    finish
    /clear
    /prep7
    *ask,LENGTH,How long is the truss,100
    *ask,HEIGHT,How tall is the truss,20
    *ask,DIVISION,How many cross supports even number,2
    DELTA_L = (LENGTH/(DIVISION/2))/2
    NUM_K = DIVISION + 1
    COUNT = -1
    X_COORD = 0
    *do,i,1,NUM_K,1
    COUNT = COUNT + 1
    OSCILATE = (-1)**COUNT
    X_COORD = X_COORD + DELTA_L
    *if,OSCILATE,GT,0,THEN
    k,i,X_COORD,0
    *else
    k,i,X_COORD,HEIGHT
    *endif
    *enddo
    KEYP = 0
    *do,j,1,DIVISION,1
    KEYP = KEYP + 1
    L,KEYP,(KEYP+1)
    *if,KEYP,LE,(DIVISION-1),THEN
    L,KEYP,(KEYP+2)
    *endif
    *enddo
    et,1,link1
    r,1,100
    mp,ex,1,200000
    mp,prxy,1,0.3
    esize,,1
    lmesh,all
    ________________________________________________
    TL lưu giử
    https://sites.ualberta.ca/~wmoussa/AnsysTutorial/CL/CAT/APDL/print.pdf
    Tạo mô hình trong /prep7 với APDL
    https://de.scribd.com/document/61608095/ANSYS-Examples-by-APDL-Hani-Aziz-Ameen
  4. umy
    Bài tập 02 Ansys APDL cho KS tự học
    https://pyansys.readthedocs.io/ansys_examples.html
    Torsional Load on a Bar using SURF154 Elements
    This ANSYS APDL script builds a bar and applies torque to it using SURF154 elements. This is a static analysis example.
    Script Initialization
    Beginning of ANSYS script:
    ! Input torque applied (moment)
    ! Input radius, height, element size...
    TORQUE = 100
    RADIUS = 2
    H_TIP = 2
    HEIGHT = 20
    ELEMSIZE = 1
    PI = acos(-1)
    FORCE = 100/RADIUS
    PRESSURE = FORCE/(H_TIP*2*PI*RADIUS)
    Corresponding pyansys script including the initialization of pyansys:
    import numpy as np
    import os
    import pyansys
    # start ANSYS in the current working directory with default jobname "file"
    ansys = pyansys.ANSYS(run_location=os.getcwd(), interactive_plotting=True)
    # define cylinder and mesh parameters
    torque = 100
    radius = 2
    h_tip = 2
    height = 20
    elemsize = 0.5
    pi = np.arccos(-1)
    force = 100/radius
    pressure = force/(h_tip*2*np.pi*radius)
    Model Creation
    APDL Script:
    ! Define higher-order SOLID186
    ! Define surface effect elements SURF154
    ! which is used to apply torque
    ! as a tangential pressure
    /prep7
    et, 1, 186
    et, 2, 154
    r,1,
    r,2,
    ! Aluminum properties (or something)
    mp,ex,1,10e6
    mp,nuxy,1,.3
    mp,dens,1,.1/386.1
    mp,dens,2,0
    ! Simple cylinder
    *do, ICOUNT, 1, 4
    cylind,RADIUS,,HEIGHTH_TIP,HEIGHT,90*(ICOUNT-1),90*ICOUNT
    *enddo
    nummrg,kp
    lsel,s,loc,x,0
    lsel,r,loc,y,0
    lsel,r,loc,z,0,HEIGHT-H_TIP
    lesize,all,ELEMSIZE*2
    mshape,0
    mshkey,1
    esize,ELEMSIZE
    allsel,all
    VSWEEP, ALL
    csys,1
    asel,s,loc,z,HEIGHT-H_TIP+0.0001,HEIGHT0.0001
    asel,r,loc,x,RADIUS
    local,11,1
    csys,0
    aatt,2,2,2,11
    amesh,all
    finish
    Corresponding pyansys script:
    # Define higher-order SOLID186
    # Define surface effect elements SURF154 to apply torque
    # as a tangential pressure
    ansys.Prep7()
    ansys.Et(1, 186)
    ansys.Et(2, 154)
    ansys.R(1)
    ansys.R(2)
    # Aluminum properties (or something)
    ansys.Mp('ex', 1, 10e6)
    ansys.Mp('nuxy', 1, 0.3)
    ansys.Mp('dens', 1, 0.1/386.1)
    ansys.Mp('dens', 2, 0)
    # Simple cylinder
    for i in range(4):
    ansys.Cylind(radius, '', '', height, 90*(i-1), 90*i)
    ansys.Nummrg('kp')
    # non-interactive volume plot (optional)
    ansys.Show()
    ansys.Menu('grph')
    ansys.View(1, 1, 1, 1)
    ansys.Vplot()
    ansys.Wait(1)
    # mesh cylinder
    ansys.Lsel('s', 'loc', 'x', 0)
    ansys.Lsel('r', 'loc', 'y', 0)
    ansys.Lsel('r', 'loc', 'z', 0, height - h_tip)
    ansys.Lesize('all', elemsize*2)
    ansys.Mshape(0)
    ansys.Mshkey(1)
    ansys.Esize(elemsize)
    ansys.Allsel('all')
    ansys.Vsweep('ALL')
    ansys.Csys(1)
    ansys.Asel('s', 'loc', 'z', '', height - h_tip + 0.0001)
    ansys.Asel('r', 'loc', 'x', radius)
    ansys.Local(11, 1)
    ansys.Csys(0)
    ansys.Aatt(2, 2, 2, 11)
    ansys.Amesh('all')
    ansys.Finish()
    # plot elements and wait one second (optional)
    ansys.Eplot()
    ansys.Wait(1)
    Element plot from pyansys using matplotlib
    Solution
    APDL script:
    /solu
    antype,static,new
    eqslv,pcg,1e-8
    ! Apply tangential pressure
    esel,s,type,,2
    sfe,all,2,pres,,PRESSURE
    ! Constrain bottom of cylinder/rod
    asel,s,loc,z,0
    nsla,s,1
    d,all,all
    allsel,all
    /psf,pres,,2
    /pbc,u,1
    /title, Simple torsional example
    solve
    finish
    /post1
    set,last
    fsum
    esel,u,type,,2
    SAVE
    # new solution
    ansys.Slashsolu() # Using Slash instead of / due to duplicate SOLU command
    # ansys('/solu') # could also use this line
    ansys.Antype('static', 'new')
    ansys.Eqslv('pcg', 1e-8)
    # Apply tangential pressure
    ansys.Esel('s', 'type', '', 2)
    ansys.Sfe('all', 2, 'pres', '', pressure)
    # Constrain bottom of cylinder/rod
    ansys.Asel('s', 'loc', 'z', 0)
    ansys.Nsla('s', 1)
    ansys.D('all', 'all')
    ansys.Allsel()
    ansys.Psf('pres', '', 2)
    ansys.Pbc('u', 1)
    ansys.Solve()
    ansys.Exit() # Finishes, saves, and exits
    Access and plot the results within python using pyansys:
    # open the result file using the path used in ANSYS
    resultfile = os.path.join(ansys.path, 'file.rst')
    result = pyansys.ResultReader(resultfile)
    # access element results as arrays
    nnum, stress = result.NodalStress(0)
    element_stress, elemnum, enode = result.ElementStress(0)
    nodenum, stress = result.NodalStress(0)
    # plot interactively
    result.PlotNodalResult(0, colormap='bwr')
    result.PlotNodalStress(0, 'Sx', colormap='bwr')
    result.PlotPrincipalNodalStress(0, 'SEQV', colormap='bwr')
    # plot and save non-interactively
    cpos = [(20.992831318277517, 9.78629316586435, 31.905115108541928),
    (0.35955395443745797, -1.4198191001571547, 10.346158032932495),
    (-0.10547549888485548, 0.9200673323892437, -0.377294345312956)]
    result.PlotNodalResult(0, interactive=False, cpos=cpos,
    screenshot=os.path.join(path, 'cylinder_disp.png'))
    result.PlotNodalStress(0, 'Sx', colormap='bwr', interactive=False, cpos=cpos,
    screenshot=os.path.join(path, 'cylinder_sx.png'))
    result.PlotPrincipalNodalStress(0, 'SEQV', colormap='bwr', interactive=False, cpos=cpos,
    screenshot=os.path.join(path, 'cylinder_vonmises.png'))
    Non-interactive Screenshot of Displacement from pyansys
    Non-interactive Screenshot of X Stress from pyansys
    Non-interactive Screenshot of von Mises Stress from pyansys
  5. umy
    Bài học 03 Ansys APDL cho KS có nghề rồi, hiểu được để áp dụng thực hành
    3.1 - ANSYS Mechanical-APDL Harmonic Analysis Example and Comparison to ANSYS Mechanical results
    http://engr.bd.psu.edu/ansysug/ANSYS M-APDL Harmonic Analysis Example and Comparison to WB.pdf
    >> TL mới 2017 tính động: modal và harmonic Analysis; so sánh kết quả của các phương pháp tính của Ansys.
    Xem kỷ phần /solu và /Post26. ở trang 23 sau cuối.
    >> (KS-Cơ khí và KS-XD) Áp dụng tính Giãm chấn cho Xe tải quân sự, Máy rung động, Cầu bộ hành ...
    3.2 - Writing Text files with *VWRITE
    http://www.padtinc.com/blog/the-focus/writing-text-files-with-vwrite
    >> cách lập trình viết codes tợ như Fortran, tạo Marcros ...
  6. umy
    Trích VUDSE:
    https://www.facebook.com/groups/vudse/
    Tien Cao:
    Việc hiển thị trong Ansys APDLkhác nhau giữa Power Graphics và Full Graphics. Khác nhau như thế nào thì bạn đọc slide sau là dễ hiểu nhất (có cả minh họa):
    https://caeai.com/sites/default/files/pg_summ.pdf(
    (ANSYS PostProcessing: Full Graphics vs. PowerGraphics)
    Bạn coi slide 6 và 7 ("If average nodal solution is requested, data is NOT averaged across material and geometric discontinuities by default"). Vậy lý do stress ko liên tục là do "geometry discontinuities".
    Nếu muốn khác phục, bạn có thể dùng Full Graphics hoặc thêm dòng sau AVRES,,FULL.
    Ngoài ra, ở slide cuối, bạn sẽ thấy tóm tắt khi nào nên dùng 2 chế độ hiển thị trên.
    Lý do chính: extrapolate stress rồi average tại node (đây là 1 vấn đề không đơn giản).
    Tham khảo thêm: https://www.sharcnet.ca/.../ds_Unaveraged_Results.html
    Đáp ngắn: (quà tết kỷ Hợi ;))
    Mô hình với Solid elements, khi dùng Power Graphics (nội suy các nút bao quanh mô hinh) đưa kết quả hình ảnh nhanh, có phần lớn hơn đôi chút . Vẫn chấp nhận được !
    .Full Graphics (được nội suy tất cả các nút) có kết quả tương đối chính xác hơn. Nếu mô hình quá lớn (trên khoãng 200.000 Nút) thì đưa Hình ảnh kết quả chậm chạp lắm.
    ginb likes this.
  7. umy
    Luận văn TS ở Đức, dùng COUPLE FIELD TRANSIENT tính cho Seals (tiếng Việt?) , có cho mã nguồn !
    NUMERICAL SIMULATION OF MECHANICAL AND THERMAL FLUID–STRUCTURE INTERACTION IN LABYRINTH SEALS
    https://d-nb.info/1005791864/34
    B.2 Excerpts from the APDL File
    Start a new solution:
    /UNITS,SI
    /PREP7
    FINISH
    /SOL
    ANTYPE,4
    TRNOPT,FULL
    NLGEOM,ON
    *SET,fsidt,0.001
    DELTIM,fsidt,fsidt,fsidt
    AUTOTS,0
    KBC,0
    TINTP,,0.3,0.6
    TIMINT,ON
    ASEL,S,,,3
    ASEL,A,,,5
    ASEL,A,,,6
    SFA,ALL,,FSIN,1
    ALLSEL,ALL
    !************* Multifield Settings ******************
    MFAN,ON
    MFPS,GROUP1,ANSYS
    MFPS,GROUP2,CFX
    MFSO,GROUP1,GROUP2
    MFLC,SURF,ANSYS,1,DISP,CFX,fsi,Total Mesh Displacement,NONC
    MFLC,SURF,CFX,fsi,Total Force,ANSYS,1,FORC,CPP
    MFTI,5
    MFDT,fsidt,fsidt,fsidt,0
    AUTOTS,OFF
    MFRS,0,SING
    MFIT,100,1,1
    MFCO,ALL,0.001
    MFCO,UZ,1.0
    MFCO,FZ,1.0
    MFRE,DISP,0.1,RELX
    MFRE,FORC,0.75,RELX
    /GST,ON,ON
    TIME,5.0
    SOLVE
    SAVE
    FINISH
    Ngoài ra cho biết thêm, để lập trình trong ANSYS ngoài APDL, có thể dùng các ngôn ngữ lập trình khác đưa vào! thí dụ như sau
    Trích VUDSE ( https://www.facebook.com/groups/vudse/)
    Khoa Luat
    Cái quan trọng nhất là bạn muốn áp dụng vào công việc gì?.
    Để học theo kiểu đơn giản, chỉ cần có ngay kết quả thì Python, Matlab/Octave, Mathematica
    Để học lập trình bài bản, tổng quát, đi theo hướng OOP, thì Java là lựa chọn số 1 vì cấu trúc rất chặt chẽ và trong sáng, hiệu năng ổn.
    Java an toàn và ít phức tạp hơn C++ trong khi tính chặt chẽ, dễ bảo trì tốt hơn Python.
    Để học ngôn ngữ hiện đại, an toàn, thanh lịch thì dùng Swift (mã nguồn mở, phát triển bởi Apple) hoặc Kotlin (officially supported by Google).
    Fortran, C không còn phổ biến nữa, người ta thường gọi các packages viết bằng các ngôn ngữ này để tận dụng về mặt tốc độ thông từ các ngôn ngữ khác (Python, Java, Matlab)
  8. umy
    Trích dựa theo bài viết
    Thanh Binh Do (VUDSE: https://www.facebook.com/groups/vudse/ )
    Một tip rất hữu ích cho ai cần nó
    ANSYS APDL Tutorial
    https://cax.vn/ansys-apdl-tutorial/
    Được sự cho phép của tác giả bộ video này là anh Đặng Hoàng Mình, giảng viên khoa cơ khí, Đại học Công nghiệp thành phố Hồ Chí Minh, [Cax.vn] giới thiệu bộ video hướng dẫn học Ansys APDL cho người mới bắt đầu.
    Bộ video được anh Minh làm với mục đích hướng dẫn cho sinh viên của trường giải quyết các bài thí nghiệm, thực hành cho môn học “Phương pháp phần tử hữu hạn“. Chính vì vậy nên nó hướng đến các ví dụ cụ thể với mức độ khó tăng dần và hoàn toàn phù hợp với người mới làm quen với Ansys ADPL.
    Kết nối Matlab với Ansys APDL
    https://cax.vn/ket-noi-matlab-voi-ansys-apdl/
    Matlab có thể thay đổi thông số đầu vào của chương trình (code) Ansys APDL để đưa ra các kết quả tính toán khác nhau dựa trên sự thay đổi đó. Nói cách khác, ta có thể khảo sát sự phụ thuộc của kết quả vào các tham số đầu vào. Để hiểu rõ hơn vấn đề này, chúng ta cùng giải quyết
    Done likes this.
