Download ebook
Kellyware KCam 4.0.38
Download Software
KCam Router/Mill software is designed to run low cost hobby CNC equipment. Program your paths using the built in Gcode editor, or import DXF, NC, and PLT files. Create signs and plates using your CAD software and import your work into KCam. Dual cutting depth allows for holes and outlines to be punched out after routing. No more drilling holes for switches or cutting plates to size before engraving.
Here are a few of the key features:
Load GM code files
Import Excellon ASCII drill files (.NC)
Import DXF files (.DXF)
Import HPGL files (.PLT)
Import Gerber files(.GB0)
Edit/Write GM code files
3D Graphical Viewer w/ Zoom, Pan and Table Views
Manual Jogging motor control
Controller and Table setup features
Supports Parallel Port (LPT) Stepper Motor Controllers
Selectable Feed Rate
Backlash Compensation
Windows 98/NT/2000/XP 32bit Software
PCB Isolation conversion from Gerber(RS274X) files
Constant Velocity Contouring
Multiple Machine Setups
more info @http://www.kellyware.com/kcam/index.htm
