' C:\Documents and Settings\Administrator\Local Settings\Temp\swx4028\Macro1.swb - macro recorded on 08/30/10 by Administrator
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.NewDocument("C:\Documents and Settings\All Users\Application Data\SolidWorks\SolidWorks 2010\templates\Part-mm-inox201.prtdot", 0, 0, 0)
swApp.ActivateDoc2 "Part1", False, longstatus
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.SketchManager.InsertSketch True
Part.ClearSelection2 True
Dim skSegment As Object
Set skSegment = Part.SketchManager.CreateLine(0#, 0#, 0#, 0.274454, 0#, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.274454, 0#, 0#, 0.274454, 0.358245, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.274454, 0.358245, 0#, 0#, 0#, 0#)
Part.SetPickMode
Part.SetPickMode
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", 0.2712745513842, 0.1201849278284, 0, False, 0, Nothing, 0)
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(0.3536870733237, 0.1705481356803, 0)
Dim myDimension As Object
Set myDimension = Part.Parameter("D1@Sketch1")
myDimension.SystemValue = 2
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0.1802499994686, 0.004866306133236, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(0.185923567571, -0.3412213481127, 0)
boolstatus = Part.Extension.SelectByID2("D1@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D2@Sketch1")
myDimension.SystemValue = 0.25
Part.SetPickMode
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 0.1432335427088, 1.361642281285, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Unknown", "MANIPULATOR", 0.01295574414159, -0.06676072443441, 0, False, 0, Nothing, 0)
Part.EditDelete
Part.SketchManager.SketchConstraintsDel 1, "sgCOINCIDENT"
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 0.07344186490495, 0.4217810201928, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point1", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 0.02226130118211, 0.407822684632, 0, False, 0, Nothing, 0)
Part.EditDelete
boolstatus = Part.Extension.SelectByID2("Point1", "SKETCHPOINT", 0, 0.1612254230583, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point1@Origin", "EXTSKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0)
Part.SketchAddConstraints "sgCOINCIDENT"
longstatus = Part.SaveAs3("C:\Documents and Settings\Administrator\Desktop\API for.SLDPRT", 0, 2)
End Sub
