Các chứng chỉ của solidworks, nội dụng thi và ví dụ đề thi.
http://www.mediafire.com/?w8kwnf1yn5z
1.
Certification
SolidWorks certifications can be used as a benchmark to measure your knowledge and competency with SolidWorks software. Exams focus on the fundamental skills necessary to ensure your company’s overall success using SolidWorks.
CSWA
As a Certified SolidWorks Associate (CSWA), you will stand out from the crowd in today’s competitive job market. CSWA certification is proof of your SolidWorks® expertise – cutting-edge skills that businesses seek out and reward.
CSWP
A Certified SolidWorks Professional is an individual that has successfully passed our advanced skills examination. Each CSWP has proven their ability to design and analyze parametric parts and moveable assemblies using a variety of complex features in SolidWorks.
CSWP-Sheet Metal
The completion of the Certified SolidWorks Professional Sheet Metal exam shows that an individual has successfully passed a skills test that demonstrates their ability to use the sheet metal tools inside of SolidWorks. Employers can be confidant that an individual possessing this certification understands the set of tools inside SolidWorks that will aid in the design of sheet metal components.
CSWP-Surfacing
SolidWorks software includes many advanced surfacing tools. The Certified SolidWorks Professional Surfacing Specialist exam is used to gauge someone’s ability to utilize these tools in the creation of complex surfaces. Successful completion of this exam also shows the user’s ability to troubleshoot and fix broken surface bodies, or imported bodies that are incorrect.
CSWSP-FEA
The Certified SolidWorks Professional Simulation Specialist exam is designed to test an individual’s complete understanding of Simulation tools inside SolidWorks. Candidates who successfully pass this certification exam have demonstrated the ability to set up, run, and examine the results of various types of Simulation scenarios. They also have demonstrated the ability to interpret the various results available to them in SolidWorks Simulation.
Certified User Directory
For a listing of Certified SolidWorks Professionals, click here.
Online Testing Process
All certification testing is done online. The process is as follows:
Step 1: Purchase your exam(s)
In order to take an online certification exam you must first visit our webstore and make a purchase.
Step 2: Take your exam(s)
Once you've purchased an online exam, you will receive two emails. One indicating that your testing account has been created, the other a receipt of your transaction. To begin your exam, simply download the virtualtester client as instructed and follow the directions. You will also need the exact information (login and password) that was supplied in the email notice.
Step 3: Print your certificate(s)
When you achieve a certification, SolidWorks provides 24-hour access to your electronic certificates. Each certified user gets a custom online account where they can view, download and print their certificates.
Note:
* All exam purchases are tied to one email. If a customer purchases more than one exam, that person may transfer the credit to another user when logged into their virtualtester account.
* If you experience any difficulty, send a detailed email to certification@solidworks.com.
* Allow up to fourteen (14) days for a resolutio
2. CSWA
Recommended Self-paced training:
SolidWorks Tutorials
Exam Length: 3 hours
Minimum Passing grade: 70%
All candidates receive electronic certifcates.
Exam features hands-on challenges in many of these areas:
3.
CSWP
Recommended Training Courses:
SolidWorks Essentials, SolidWorks Drawings, Advanced Part Modeling and Advanced Assembly Modeling.
Minimum Passing grade: 75%
All candidates receive electronic certifcates, business card logos and personal listing on CSWP directory when they pass.
* Sketch entities - lines, rectangles, circles, arcs, ellipses, centerlines
* Sketch tools - offset, convert, trim
* Sketch relations
* 3D sketching
* Boss and cut features - extrudes, revolves, sweeps, lofts
* Fillets and chamfers
* Draft
* Shell
* Hole Wizard
* Linear, circular and fill patterns
* Mirror
* Dimensions
* Feature conditions – start and end
parts
* Combine – add, subtract, common
* Move/Copy body
* Split
* Join
* Rib
* Scale
* Indent
* Helix/Spiral
* Curves – projected, composite
* Splines
* Intersection curve
* Guide curves, hold lines
* Library features
* Feature scope
* Mass properties
* Move/Delete face
* Materials
* Linear static analysis
* Loads – force, pressure
* Restraints
* Optimizing - Factor of safety
* Max von Mises stress location
* Max displacement location
* Inserting components - new and existing
* Standard mates - coincident, parallel, perpendicular, tangent, concentric, distance, angle
* Advanced mates - symmetric, cam, width, gear, rack and pinion, limit
* Reference geometry – planes, axis, mate references
* In-context features
* Smart Components
* Smart Fasteners
* Smart Mates
* Interference detection
* Suppression states
* Move/Rotate component
* Exploded view
* Simulation
* Assembly features
* External references
* Design tables
* Drawing sheets and views
* Dimensions and model items
* Annotations
* Formats and templates
* Assembly views – configurations, broken out section view, alternate position view, exploded view
* Bill of Materials
* Custom properties
4.
CSWP-Sheet Metal
Solidworks Essentials
Sheet Metal
Exam Length: 2 hours
All candidates receive electronic certificates and a personal listing on the CSWP directory when they pass.
Exam features hands-on challenges in many of these areas of SolidWorks Sheet Metal functionality:
* Linear Edge Flange
* Curved Edge Flange
* Miter Flange
* Closed Corner
* Gauge Tables
* Bending calculation options:
* Bend Allowance
* Bend Deduction
* K-Factor
* Hem
* Jog
* Sketched Bend
* Forming Tool
* Unfold and Fold
* Flatten
5.
CSWP-Surfacing
Advanced Surface Modeling
Exam Length: 90 minutes
All candidates receive electronic certificates and personal listing on the CSWP directory when they pass.
Note: You must use at least SolidWorks 2008 sp3.1 for this exam. Any use of a previous version will result in the inability to open some of the testing files.
Exam features hands-on challenges in many of these areas of the SolidWorks Surfacing functionality:
* Spline Creation
* 3D Curve Creation
* Boundary Surface
* Filled Surface
* Swept Surface
* Planar Surface
* Knit Surface
* Trim Surface
* Untrim Surface
* Move Face
* Extend Surface
* Fillet
* Thicken
1.
Certification
CSWA
CSWP
CSWP-Sheet Metal
CSWP-Surfacing
CSWSP-FEA
Note:
2. CSWA
3.
CSWP
* Sketch relations
* 3D sketching
* Draft
* Shell
* Hole Wizard
* Mirror
* Dimensions
* Move/Copy body
* Split
* Join
* Rib
* Scale
* Indent
* Helix/Spiral
* Splines
* Library features
* Feature scope
* Mass properties
* Move/Delete face
* Materials
* Restraints
* Smart Components
* Smart Fasteners
* Smart Mates
* Exploded view
* Simulation
* Assembly features
* Design tables
* Annotations
* Bill of Materials
* Custom properties
4.
CSWP-Sheet Metal
Sheet Metal
* Miter Flange
* Closed Corner
* Gauge Tables
* Bend Allowance
* Bend Deduction
* K-Factor
* Hem
* Jog
* Sketched Bend
* Forming Tool
* Unfold and Fold
* Flatten
5.
CSWP-Surfacing
* Spline Creation
* 3D Curve Creation
* Boundary Surface
* Filled Surface
* Swept Surface
* Planar Surface
* Knit Surface
* Trim Surface
* Untrim Surface
* Move Face
* Extend Surface
* Fillet
* Thicken
