Mình copy các bản vẽ dùng solidwork 2009, về nhà mình mở bằng SL2008 máy báo không hiểu file. Có ai biết save ở SL2009 bằng cách nào để mở được trên SL 2008 không vây? Ai biết chỉ cho mình với. Thank...!
Ðề: Làm thế nào để mở file solidwork 2009 bằng Solidwork2008?
chào anh em
các anh em đừng có cố mở flie solid2009 bằng 2008 sẽ ko bao giờ làm được đâu
vì tính chất thương mại người ta đã sản xuất ra 2009 và người ta đã cố tình làm như vậy .
What should I do before I upgrade to SolidWorks 2009?
Update your Video Card to a SolidWorks Certified Driver. SolidWorks recommends the use of certified graphics cards and systems. A certified graphics card or system is tested to a higher standard and is supported by the vendor. A listing of the latest Certified Drives may be found at the link: http://www.solidworks.com/pages/services/VideoCardTesting.html
Please note, if you are running a DELL or HP workstation, please be sure to select them when making your video card vendor selection even if your video card in your system is from nVidia or ATI.
Check System Requirements to ensure successful installation and optimum performance, verify that your system complies with the requirements: www.solidworks.com/System_Requirements
Administrative rights are necessary on the local system in order to perform SolidWorks installation or upgrades. System DLLs and drivers are updated which require administrative privileges. The necessary permissions will have to be obtained to ensure a successful installation of SolidWorks. Only read and execute permission are required to run SolidWorks.
Disable any
or
applications that you may have running.
This step must include terminating any
or
services that are running. Certain
application do not allow for system resources to be updated if they are in use. For a list of
Save copies of all SolidWorks parts, assemblies, and drawings in your current version prior to upgrade. We recommend the creation of a backup copy of your SolidWorks Data. Once the files are converted and saved in SolidWorks 2009, these files are no longer accessible in previous versions of SolidWorks software.
Backup all of your custom document templates, sheet formats, or design library items from previous releases before installing SolidWorks 2009.
Can I have more than one version of SolidWorks installed on my system at the same time?
Yes, it is possible to have multiple versions of SolidWorks on the same system. During install, specify separate paths for the install directory and the common files directory. Please be aware that SolidWorks does not support backward compatibility.
Will SolidWorks 2009 files open in SolidWorks 2008?
No, SolidWorks is not backwards compatible. Once a file has been saved in SolidWorks 2009, it cannot be opened in SolidWorks 2008 unless it is exported as a neutral file (i.e. Parasolid). Note that when importing a neutral file all feature data history is NOT included.
Chúc các bạn thành công trên con đường học vấn của mình.
Solution Id:
S-028653
Product:
Updated:
6/26/2009 07:45:26 PM
Area:
Student Editions
Sub-Area:
Informational? SE
Question:
I own SolidWorks® Student Edition 2007-2008 but my school is using the Student Edition 2008-2009 version. Is it possible to work on files using the 2008-2009 version and then work on these same files at home using the 2007-2008 version?
Answer:
SolidWorks® Student Edition is not backward compatible. Once the files are converted to a higher version, they can not be opened by a lower version of SolidWorks. The same is applicable to new files created with a higher version.
