Ðề: download solidworks and solidcam 2010
Bác nào biết sửa lỗi sau giúp mình với.
Máy mình dùng win7 x64. Mình mới tải về bản solidcam 2010 sp0 x64. Cài đặt báo thành công hết (máy mình đã cái bản Solidworks 2010 sp0 x64). Nhưng khi chạy solidworks, mở sang solidcam thì bị báo lỗi như sau:
"Cannot activate solidcam. Please verify that solidcam hardware key is connected"
Cao thủ nào biết sửa lỗi này cho mình biết với.
1) You need a local Administrator rights to install this emulator for Win64!
On Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!
2) Install SolidCAM 2010 64bit
3) Reboot computer (for Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!)
4) Run "solidcam2010.reg" (confirm to add info to Windows Registry)
5) To install USB-Emul_Win64
Start -> Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..
If setup is succesfull you have to see new devices:
Device Manager -> System devices -> Virtual Usb Bus Enumerator
Device Manager -> Universal Serial Bus controllers ->SafNet inc. HASP key
Device Manager -> Universal Serial Bus controllers ->SafNet inc. USB key
That is all, enjoy
Đấy là hướng dẫn trong phần Cr@ck của nó. Hixx, làm theo y chang mà không ăn thua.
Xin liên hệ qua hòm thư
Strongwillvn@gmail.com
