G
trong lúc phân tích cool trong moldflow 2010 em bị lỗi này. mong các bác giúp đỡ !!!
Copyright Autodesk, Inc. All rights reserved.
(C)2009
Portions of this software are covered by U.S. Patent Numbers 5,287,408 and 6,096,088.
Cool Analysis
Version: ami2010-main (Build 09034-001)
32-bit build
Analysis running on host:
Operating System: Windows Vista
Processor type: GenuineIntel x86 Family 6 Model 37 Stepping 2 ~2261 MHz
Number of Processors: 4
Total Physical Memory: 3508 MBytes
Analysis commenced at Thu Sep 27 16:04:58 2012
Executed: Thu Sep 27 16:04:59 2012
Mesh Type = Dual Domain
Number of nodes = 32750
Number of beam elements = 200
Number of triangular elements = 64917
Number of tetrahedral elements = 0
Reading nodal data...
Reading beam element data...
Reading triangular element data...
Analysis has detected a mesh change since initial mesh
generation ... recalculating mesh match and thickness information
Processing Dual Domain mesh...
Computing match using the maximal-sphere algorithm
... finished processing Dual Domain mesh
Method of calculating geometrical influence = Ideal
Cool analysis type = Automatic
Total number of part elements = 64917
Total number of mold elements = 548
Total number of circuit elements = 200
Co-ordinates of part extremity:
X Y Z
Maximum 140.09306 mm 40.08034 mm 55.00031 mm
Minimum -40.09368 mm -140.07798 mm -5.39972 mm
Orientation 320.27978 mm 220.23866 mm 115.40034 mm
** WARNING 701350 ** The aspect ratio of element 5715 is very high
** WARNING 701350 ** The aspect ratio of element 79668 is very high
** WARNING 701350 ** The aspect ratio of element 79670 is very high
** WARNING 701350 ** The aspect ratio of element 80207 is very high
** WARNING 701380 ** Warnings were reported in the model.
Mesh quality may be poor.
Co-ordinates of mold extremity:
X Y Z
Center 49.99968 mm -49.99882 mm 24.80030 mm
Right corner 350.80636 mm 250.80785 mm 325.60697 mm
Left corner -250.80699 mm -350.80549 mm -276.00637 mm
** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.
Angle between normals = 1.78297E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element 3657
** ERROR 701590 ** Check the orientation of element 3666
Angle between normals = 1.78298E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element 69272
** WARNING 98000 ** The following warning messages occurred more than 5 times:
Message No. Number of occurrences
701350 79
** ERROR 99002 ** The following error messages occurred more than 5 times:
701590 28
701350 79
701590 28
(C)2009
Cool Analysis
32-bit build
X Y Z
X Y Z
701350 79
701590 28
701350 79
701590 28
