giờ mới lấy được link xong.
bản NX các bạn đang dùng chỉ là bản NX version 8.0 thôi ( NX Version 8.0 | Release September 2011) . đây là bản update cho nó. :65:
32 bit http://115.com/file/aq6zvnuu#
64 bit http://115.com/file/dng68tiv#
để cho ko có lỗi xảy ra ngoài mong muốn thì nên cái NX mới -> update -> xxx
have fun! ^.^
đây là các lỗi được fix, bạn nào ko bị các lỗi này trên máy thì khỏi update chi cho mất thời gian :103:
Date: 27 October 2011
Subject: Maintenance Pack 1 for NX 8.0.0
To: All users of NX 8.0.0
have fun! ^.^
Release | PR Number | Problem Description |
MP1 | 1857432 6575675 | The problem in NX Open Java where jar file handles were not released is fixed. |
MP1 | 1859095 | The problem in Motion where motion simulation did not work correctly with the RecurDyn solver is fixed. |
MP1 | 1866242 1866402 | The problem in Advanced Simulation where geometry update was failing is fixed. |
MP1 | 1866900 | The problem where running an NXOpen.Net Journal caused the error "Invalid NX signature found" is fixed. |
MP1 | 1867753 | The problem in Electrode Wizard where the Create Box command was not available is fixed. |
MP1 | 2176022 | The problem where the partial loading of an assembly with PMI data which referenced geometry that no longer existed in a sub-component caused an error is fixed. The problem where loading an assembly with PMI data which referenced geometry in an unloaded sub-assembly caused an error is fixed. |
MP1 | 6550403 | The problem where Human Modeling did not work after running a custom NX Open API which also called a Python 2.5 application is fixed. |
MP1 | 6582972 6583074 | The problem where the NX Shape Search was missing the 3-digit prefix in the username and the display thumbnails did not appear in the preview window is fixed. |
MP1 | 6583444 6598439 | The problem in Advanced Simulation where an Abaqus model failed to import due to multiple *HEADING keywords in the main deck and included decks is fixed. The problem in Advanced Simulation where an Abaqus deck was imported with incorrect steps is fixed. |
MP1 | 6588676 1864107 1864347 1865119 6588699 | The problem in Manufacturing where creating a tool caused an error when an ug_isv_full license was not available is fixed. |
MP1 | 6589887 | The problem in Mold Wizard where multiple tree list items could not be selected in Part Name Management is fixed. |
