Ðề: Một số điều thú vị khi sử dụng NX
một ít hotkey, có thể có ích cho các bạn ^.^
[TD="class: xl24, width: 318"]Edit-Undo List-Invalid menu entry [/TD]
[TD="class: xl22, width: 89"]Ctrl+Z [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_UNDO [/TD]
[TD="class: xl24, width: 318"]Edit-Cut [/TD]
[TD="class: xl22, width: 89"]Ctrl+X [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_CUT [/TD]
[TD="class: xl24, width: 318"]Edit-Copy [/TD]
[TD="class: xl22, width: 89"]Ctrl+C [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_COPY [/TD]
[TD="class: xl24, width: 318"]Edit-Paste [/TD]
[TD="class: xl22, width: 89"]Ctrl+V [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_PASTE [/TD]
[TD="class: xl24, width: 318"]Edit-Delete... [/TD]
[TD="class: xl22, width: 89"]Ctrl+D [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_DELETE [/TD]
[TD="class: xl25, colspan: 2"]Edit-Selection-Top Selection Priority - Feature F[/TD]
[TD="class: xl23, width: 235"]UG_SEL_FEATURE_PRIORITY [/TD]
[TD="class: xl25, colspan: 2"]Edit-Selection-Top Selection Priority - Face G[/TD]
[TD="class: xl23, width: 235"]UG_SEL_FACE_PRIORITY [/TD]
[TD="class: xl25, colspan: 2"]Edit-Selection-Top Selection Priority - Body B[/TD]
[TD="class: xl23, width: 235"]UG_SEL_BODY_PRIORITY [/TD]
[TD="class: xl25, colspan: 2"]Edit-Selection-Top Selection Priority - Edge E[/TD]
[TD="class: xl23, width: 235"]UG_SEL_EDGE_PRIORITY [/TD]
[TD="class: xl25, colspan: 2"]Edit-Selection-Top Selection Priority - Component C[/TD]
[TD="class: xl23, width: 235"]UG_SEL_COMPONENT_PRIORITY[/TD]
[TD="class: xl24, width: 318"]Edit-Selection-Select All [/TD]
[TD="class: xl22, width: 89"]Ctrl+A [/TD]
[TD="class: xl23, width: 235"]UG_SEL_SELECT_ALL [/TD]
[TD="class: xl24, width: 318"]Edit-Blank-Blank... [/TD]
[TD="class: xl22, width: 89"]Ctrl+B [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_BLANK_SELECTED [/TD]
[TD="class: xl24, width: 318"]Edit-Blank-Reverse Blank All [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+B [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_REVERSE_BLANK_ALL[/TD]
[TD="class: xl24, width: 318"]Edit-Blank-Unblank Selected... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+K [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_UNBLANK_SELECTED[/TD]
[TD="class: xl24, width: 318"]Edit-Blank-Unblank All of Part [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+U [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_UNBLANK_ALL_OF_PART[/TD]
[TD="class: xl24, width: 318"]Edit-Transform... [/TD]
[TD="class: xl22, width: 89"]Ctrl+T [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_TRANSFORM [/TD]
[TD="class: xl24, width: 318"]Edit-Object Display... [/TD]
[TD="class: xl22, width: 89"]Ctrl+J [/TD]
[TD="class: xl23, width: 235"]UG_EDIT_OBJECT_DISPLAY [/TD]
[TD="class: xl24, width: 318"]View-Operation-Zoom... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+Z [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_ZOOM [/TD]
[TD="class: xl24, width: 318"]View-Operation-Rotate... [/TD]
[TD="class: xl22, width: 89"]Ctrl+R [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_ROTATE [/TD]
[TD="class: xl24, width: 318"]View-Operation-Section... [/TD]
[TD="class: xl22, width: 89"]Ctrl+H [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_SECTIONING [/TD]
[TD="class: xl24, width: 318"]View-Layout-New... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+N [/TD]
[TD="class: xl23, width: 235"]UG_LAYOUT_NEW [/TD]
[TD="class: xl24, width: 318"]View-Layout-Open... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+O [/TD]
[TD="class: xl23, width: 235"]UG_LAYOUT_OPEN [/TD]
[TD="class: xl24, width: 318"]View-Layout-Fit All Views [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+F [/TD]
[TD="class: xl23, width: 235"]UG_LAYOUT_FIT_ALL_VIEWS [/TD]
[TD="class: xl24, width: 318"]View-Visualization-High Quality Image[/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+H [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_HIGH_QUALITY_IMAGE[/TD]
[TD="class: xl24, width: 318"]View-Information Window [/TD]
[TD="class: xl22, width: 89"]F4 [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_INFO_WINDOW[/TD]
[TD="class: xl24, width: 318"]View-Current Dialog [/TD]
[TD="class: xl22, width: 89"]F3 [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_CURRENT_DIALOG[/TD]
[TD="class: xl24, width: 318"]View-Reset Orientation [/TD]
[TD="class: xl22, width: 89"]Ctrl+F8 [/TD]
[TD="class: xl23, width: 235"]UG_VIEW_RESET_ORIENTATION[/TD]
[TD="class: xl24, width: 318"]Format-Layer Settings... [/TD]
[TD="class: xl22, width: 89"]Ctrl+L [/TD]
[TD="class: xl23, width: 235"]UG_LAYER_SETTINGS [/TD]
[TD="class: xl24, width: 318"]Format-Visible in View... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+V [/TD]
[TD="class: xl23, width: 235"]UG_LAYER_VIEW [/TD]
[TD="class: xl24, width: 318"]Format-WCS-Display [/TD]
[TD="class: xl22, width: 89"]W [/TD]
[TD="class: xl23, width: 235"]UG_WCS_DISPLAY [/TD]
[TD="class: xl24, width: 318"]F... [/TD]
[TD="class: xl22, width: 89"]Ctrl+N [/TD]
[TD="class: xl23, width: 235"]UG_FILE_NEW [/TD]
[TD="class: xl22, width: 89"]Ctrl+O [/TD]
[TD="class: xl23, width: 235"]UG_FILE_OPEN [/TD]
[TD="class: xl24, width: 318"]F [/TD]
[TD="class: xl22, width: 89"]Ctrl+S [/TD]
[TD="class: xl23, width: 235"]UG_FILE_SAVE_PART [/TD]
[TD="class: xl24, width: 318"]F As... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+A [/TD]
[TD="class: xl23, width: 235"]UG_FILE_SAVE_AS [/TD]
[TD="class: xl22, width: 89"]Ctrl+P [/TD]
[TD="class: xl23, width: 235"]UG_FILE_PLOT [/TD]
[TD="class: xl24, width: 318"]F-Grip... [/TD]
[TD="class: xl22, width: 89"]Ctrl+G [/TD]
[TD="class: xl23, width: 235"]UG_FILE_RUN_GRIP [/TD]
[TD="class: xl24, width: 318"]F-Debug Grip... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+G [/TD]
[TD="class: xl23, width: 235"]UG_FILE_RUN_GRIP_DEBUG [/TD]
[TD="class: xl24, width: 318"]F-NX Open... [/TD]
[TD="class: xl22, width: 89"]Ctrl+U [/TD]
[TD="class: xl23, width: 235"]UG_FILE_RUN_UFUN [/TD]
[TD="class: xl24, width: 318"]Tools-Expression... [/TD]
[TD="class: xl22, width: 89"]Ctrl+E [/TD]
[TD="class: xl23, width: 235"]UG_INSERT_DLEXPRESSION [/TD]
[TD="class: xl24, width: 318"]Tools-Journal-Play... [/TD]
[TD="class: xl22, width: 89"]Alt+F8 [/TD]
[TD="class: xl23, width: 235"]UG_JOURNAL_PLAY [/TD]
[TD="class: xl24, width: 318"]Tools-Journal-Edit [/TD]
[TD="class: xl22, width: 89"]Alt+F11 [/TD]
[TD="class: xl23, width: 235"]UG_JOURNAL_EDIT [/TD]
[TD="class: xl24, width: 318"]Tools-Macro-Start Record... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+R [/TD]
[TD="class: xl23, width: 235"]UG_MACRO_RECORD [/TD]
[TD="class: xl24, width: 318"]Tools-Macro-Playback... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+P [/TD]
[TD="class: xl23, width: 235"]UG_MACRO_PLAYBACK [/TD]
[TD="class: xl24, width: 318"]Tools-Macro-Step... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+S [/TD]
[TD="class: xl23, width: 235"]UG_MACRO_STEP [/TD]
[TD="class: xl24, width: 318"]Preferences-Object... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+J [/TD]
[TD="class: xl23, width: 235"]UG_PREFERENCES_OBJECT [/TD]
[TD="class: xl24, width: 318"]Preferences-Selection... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+T [/TD]
[TD="class: xl23, width: 235"]UG_PREFERENCES_SELECTION [/TD]
[TD="class: xl24, width: 318"]Information-Object... [/TD]
[TD="class: xl22, width: 89"]Ctrl+I [/TD]
[TD="class: xl23, width: 235"]UG_INFO_OBJECT [/TD]
[TD="class: xl24, width: 318"]Analysis-C Curvature Graphs[/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+C [/TD]
[TD="class: xl23, width: 235"]UG_INFO_MB_SHOW_GRAPHS [/TD]
[TD="class: xl24, width: 318"]Application-Modeling... [/TD]
[TD="class: xl22, width: 89"]Ctrl+M [/TD]
[TD="class: xl23, width: 235"]UG_APP_MODELING [/TD]
[TD="class: xl24, width: 318"]Application-Shape Studio... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Alt+S [/TD]
[TD="class: xl23, width: 235"]UG_APP_STUDIO [/TD]
[TD="class: xl24, width: 318"]Application-Drafting... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Shift+D [/TD]
[TD="class: xl23, width: 235"]UG_APP_DRAFTING [/TD]
[TD="class: xl24, width: 318"]Application-Manufacturing... [/TD]
[TD="class: xl22, width: 89"]Ctrl+Alt+M [/TD]
[TD="class: xl23, width: 235"]UG_APP_MANUFACTURING [/TD]
[TD="class: xl24, width: 318"]Application-Sheet Metal-NX Sheet Metal[/TD]
[TD="class: xl22, width: 89"]Ctrl+Alt+N [/TD]
[TD="class: xl23, width: 235"]UG_APP_SBSM [/TD]
[TD="class: xl24, width: 318"]Application-Gateway... [/TD]
[TD="class: xl22, width: 89"]Ctrl+W [/TD]
[TD="class: xl23, width: 235"]UG_APP_GATEWAY [/TD]
[TD="class: xl24, width: 318"]Help-On Context... [/TD]
[TD="class: xl22, width: 89"]F1 [/TD]
[TD="class: xl23, width: 235"]UG_HELP_ON_CONTEXT [/TD]
1 trang web cũng khá hay về NX, nhưng mà nó chặn IP VN nên muốn vào nó phải fake IP, đây ko phải là web chia sẻ các tut hay các tool , nhưng nếu có vấn đề thắc mắc khi sử dụng (làm sao để hiển thị tốt nhất hình ảnh, tai sao cái hệ tọa độ nó bé thế, xử lý dữ liệu file khi bị lỗi v.v..) , đôi lúc mình cũng tìm được vấn đề trên này, cứ search từ khóa tiếng anh tương ứng tham khảo xem sao. :11:
http://www.eng-tips.com/threadminder.cfm?pid=561&page=1
