Ðề: Phần mềm chế tạo khuôn tích hợp với Solidworks.
Của các bạn đây
SolidWorks 2009 - MoldWorks SplitWorks ElectrodeWorks (Update 08.02.2010) | 384MB
Year: 2009
Developer: R & B
Compatibility with Vista: Yes
Language: Multi
System Requirements: SolidWorks Version 2009
Operating System (for MoldWorks) MS Windows XP / Vista - 32 & 64bit
Operating System (for SplitWorks) MS Windows XP / Vista - 32 & 64bit
Operating System (for ElectrodeWorks) MS Windows XP / Vista - 32 & 64bit
Graphics 1024x768 resolution with minimum 32768 colours
Disk Space 5GB free
Memory 1GB RAM (2GB recommended)
MoldWorks - automated layout molds. MoldWorks applied, first, to reduce the cycle of design work. Time layout mold in the system MoldWorks takes several hours, in contrast to 1,5 - 2 weeks at the usual design, even with the computer.
MoldWorks helps to optimize the size of the package and the location of its nodes, the place to edit individual components of the mold.
When manually designing the designer can not guarantee the full efficiency of the construction at the stage of its development, which is quite difficult to do, working with individual types of the drawing. As a result, mold is subjected to repeated testing and f
in the tool shop.
The system can analyze MoldWorks collection forms and efficiency of its units, to provide peresekaemost work in the form of individual parts (piston and the side bars having a joint working zone).
A large percentage of marriages in the manufacture of molds associated with design errors in the calculation of the cooling system. MoldWorks analyzes the thickness of the wall, helping to avoid the intersection of cooling holes with other holes.
Fast build molds in MoldWorks due to the use of parametric 3-D object-oriented libraries of parts molds of several international standards (DME, HASCO, NATIONAL, RABOURDIN, FUTABA, EOC, STRACK). All the components used molds are graphic and informative description and positioned in the assembly in accordance with their appointment.
Splitworks - a tool for complex surfaces of the connector, the surfaces of the matrix and punch.
Splitworks possible to simulate a plane connector, and generate the model of matrices of punches, with the complex surfaces of the connector that is not always possible to do this standard means of SolidWorks.
ElectrodeWorks - allows you to automate all aspects of calculation and design of electrodes for electrical discharge machining (EI).
Design of EI is based on the geometry of the shape forming cavities matrices and punches the mold.
Download:
Code:
Link bị xóa vì vấn đề bản quyền, xin hãy liên hệ tác giả bài viết nếu bạn có thắc mắc
Các bạn vào đây tham khảo thêm của bạn Hoàng Khương nhé (tài liệu rất hay và trực quan)
http://meslab.org/mes/showthread.php?t=2754&page=3
