ArtCAM Function Keyboard Shortcut
View Control
Switch to 2D view F2
Switch to 3D view F3
Switch Assistant / Toolpath Manager F4
Toggle through Assistant, Layers, Toolpath windows etc. Alt + Tab
Vector Drawing
Create object and close page Enter or Right mouse button
Create and continue Space bar
Cancel and close page Esc.
Close Polyline Tab
Vector Modes
Selection Mode Esc
Node and
Editing N
Transform vector(s) T
Transform vector(s) with dialog T (Press Twice)
Edit 2D shape E
Fillet Vectors F
Selection Mode
Start point P
Cut vector C
Join vectors with coincident points J
Constrain drag to x or y axis Alt
Create copy on drag Ctrl
Node and
Editing Mode
Span Editing
Convert span(s) to line L
Convert span(s) to Bezier B
Convert span to arc A
Cut vector C
Remove span(s) R
Point Editing
Insert a point I
Delete point(s) D
Smooth point(s) On / Off S
Start point P
Align points in X (from last in selection) X
Align points in Y (from last in selection) Y
Transform Mode
Scale proportionally Shift
Scale about centre Alt
Vector Alignment
Centre in Page F9
Left Ctrl + Left arrow
Horizontal Centre Shift + Left arrow
Right Ctrl + Right arrow
Top Ctrl + Up arrow
Vertical Centre Shift + Down arrow
Bottom Ctrl + Down arrow
Vector Grouping
Group objects Ctrl + G
Ungroup objects Ctrl + U
Zoom Control
2D Design view
2D view Zoom in Ctrl + Right mouse button
2D view Zoom out Shift + Right mouse button
3D Display view
3D view twiddling Left mouse button
3D view Zoom in / out Push / Pull Right mouse button
3D view Pan Left + Right mouse button
General
Multiple selection Shift + Left mouse button
Copy to clipboard Ctrl + C
Paste from clipboard Ctrl + V
Edit Undo Ctrl + Z
Edit Redo Ctrl + A
Cut vector(s) Ctrl + X
Save File Ctrl + S
Open File Ctrl + O
Edit / Add Guidelines Double click on a guide line
View Control
Vector Drawing
Close Polyline Tab
Vector Modes
Selection Mode Esc
Node and
Edit 2D shape E
Fillet Vectors F
Selection Mode
Start point P
Cut vector C
Node and
Span Editing
Cut vector C
Remove span(s) R
Point Editing
Insert a point I
Delete point(s) D
Start point P
Transform Mode
Vector Alignment
Centre in Page F9
Top Ctrl + Up arrow
Vector Grouping
Zoom Control
2D Design view
3D Display view
General
Edit Undo Ctrl + Z
Edit Redo Ctrl + A
Save File Ctrl + S
Open File Ctrl + O
